4 Replies Latest reply on Feb 12, 2015 2:49 PM by Heinz Navratil
    Excel Object
    Dave Olson
      I've prepared a SolidWorks macro (snippets below) that references an Excel workbook. Upon completion of the macro, I exit the Excel application and free the memory associated with the Excel object. I've used this process successfully in many other applications. In SolidWorks, the Excel application continues to reside in the Task Manager (thus locking the spreadsheet). The Excel process must be manually killed from Task Manager to close the workbook and terminate Excel. I don't want to add code to indiscriminately kill an Excel process in case another sheet is open. Does anyone know why the worksheet isn't closed from within SolidWorks?
      Dim xlApp As Object
      Set xlApp = CreateObject("Excel.Application")
      Do Things
      xlApp.DisplayAlerts = False
      xlApp.Quit
      Set xlApp = Nothing
        • Re: Excel Object
          Keith Rice
          Dave,
          This has long been a problem. See my blog post Using Microsoft Excel with the SolidWorks API for how to ensure that the EXCEL.EXE process will end without blunting killing the process using TASKKILL.
          By the way, to make this thread easier to find for others with this problem, please consider renaming it to "EXCEL.EXE process remains in Task Manager" or something more specific than your current title.
          Keith
          SolidWorks API Training
          • Re: Excel Object
            Heinz Navratil
            Hi Dave,
            I had the same problem, I found the following solution in the WWW which works fine for me
            as you have a connection to excel like
                        exc = CreateObject("Excel.Application")
                        exc.Visible = False
                        wbs = exc.Workbooks
                       wb.Save()
                       wb.Close()
                       exc.Quit()
                       releaseObject(exc)
                       releaseObject(wbs)
            Private Sub releaseObject(ByVal obj As Object)
                    Try
                        System.Runtime.InteropServices.Marshal.ReleaseComObject(obj)
                        obj = Nothing
                    Catch ex As Exception
                        obj = Nothing
                    Finally
                        GC.Collect()
                    End Try
