Sorry, but I am so p...d! off. I keep coming upon issues where Solidworks keeps failing, and my 30 years with Pro/E did not.
I'm on a deadline and working tonight and I hate even spending the time to do this. I had a part in an assembly that was assembled with a plane to a plane. The user had created the plane offset from a side surface. When the user changed the location of some holes that should have been centered on the assembly he did not change the offset. I modified the part so that the plane was defined through the axes of the holes. BAM! Major failure of assembly constraints with no idea, no information on why. The axes of the holes I changed the plane to go through were parallel with the surface the plane had originally been defined from. Even flipping the plane orientation did not correct the issue.
I keep encountering stuff like this that drives me crazy. I have many examples:
1) Sheetmetal conversion features - sometimes you just have to start with a solid part and convert to sheetmetal. But I have had major issues with changing the underlying boss feature and BAM! features and/or dimensions that follow the conversion suddenly lose all references, even though I have not changed the geometry where surfaces, edges or vertices have changed. It must be that with modifyiing the underlying feature Solidworks re-solves and renames all the references that were created, even though no references have really changed. I never had an issue with Pro/E except when surfaces, edges or vertices dis-appeared. I do find that if I change dimension values in small increments it sometimes works, but who wants to do that.
2)Cross sections in drawings - I have major blowups in Solidworks when a cross-section cut cuts a feature that would create a line or a point. Never had a problem in Pro/E. In Solidworks I get messages that invalid geometry would be created. In Pro/E I get the cross-section.
3) The issue I first mentioned - parallel axes and surface. Move the plane definition from one to the other and BAM!
(Sorry about the BAM!, but the owner of our company keeps telling me about his ideas and BAM!, Simple! Done!. If only Solidworks was BAM! Simple! Done! then I'd be home free.)
4) This way of Solidworks not caring about the order of assembly - in Pro/E I got very used to assemble and solve constraints in order. With Solidworks they say you can assemble helter-skelter. But can you? Even though I try very carefully to follow my Pro/E experience with Solidworks (one component followed by its location info) I find down the road one additional constraint and BAM! No information on really why the assembly is failing.
5) OK, since I'm on a rant, why do pop-up toolbars keep popping up on top of what you are trying to edit. Can't they keep their focus so they know what you are editing?
6) Select other - I have revision symbols, view captions and views all in close proximity. So I use Select Other, select the underlying item and then what? Whatever Solidworks wants. A very experienced user told me to move the other stuff out of the way before I could deal with what's beneath. With Pro/E, RMB, RMB until the item is highlighted and then do with it what you want.
7) Import - When I converted from Pro/E to Solidworks I did major STEP export /imports from Pro/E to Solidworks and checked them into the EPDM database. I am still correcting this information because all radiused and cylindrical surfaces came in as splines - hardly useful for assembly purposes - and this was on the recommendation of my VAR and several internet resources. Other CAD importers of the same Pro/E step files imported the cylindrical surfaces properly. Why did Solidworks cause me so much work to correct this data?
Look, I am stuck with Solidworks and I am really trying very hard to make it work. It has some really nice things going for it graphically (except I'm comparing it to Pro/Engineer Wildfire 2.0 which I really like) and I keep finding things that really frustrate and limit me 10 years after the software I was used to was released. So why doesn't Solidworks have the stability, capability ease of use, and exactness that a software 10 years ago had?
As Sean Connery stated in the Untouchables, "so endith the lesson" or me in 2015, "So endith the rant"..
Andrew
Some day's I feel your pain -
Use a Sketch Part as the main component to which you make all changes and that will help eliminate most of the "New" insert parts in an assembly - Use that part in all your sub-assemblies as the first or top component in your feature manager tree
Get more training
