I have a huge part part that has a lot of bodies . My problem I want to print one of the bodies. When I turn off visibility of all unwanted features and have only the part I want to print visible and save it to STL, then when I import it into my printer graphics area , all the model shows up. How do I save so I can only print this small portion of my file?
JB
In the multi body part, select the body you want to export by selecting it in the solid/surface body folder. Then do the save as STL. Finally pick the option "selected bodies" from the pop up window.
If not then you can insert the body into a new part and save that as STL (quite simple). For this expand the solid/surface body folder, right click on the body you want to print and then select insert into new part.
