I am calculationg stength of a pressure vessel with a hinged door, and want to simulate the hinges as pin connectors
As a linear model, the solver works fine, but when running a nonlinear model, it will not start and gives no error message,
The meshing works fine, and so does the solver if I use a rigid connection or a link
Are there any limitation so that Nonlinear static does not support the pin connector?
I ame using SW2015 and Simulation Premium
Best regards
Torkil
did you redefine the pin in nonlinear?
