1 Reply Latest reply on Jan 30, 2015 4:48 AM by Simon Turner
    SketchManager:: MakeSketchBlockFromFile Angle
    Joecel Torres
      I`m trying to insert a block in a drawing file.
      Some blocks are horizontal while others, vertical.
      For the vertical blocks, I`m trying to use "90" for the Angle but the output in incorrect.
      I tried using 0, 90, 180 and 270 for further testing.
      Please see the attached file for the output.
      Here`s my code snippet:
      MathUtility mathUtil = swApp.GetMathUtility();
      MathPoint mathPt = (MathPoint)mathUtil.CreatePoint(new double[3] { viewOutline[0] * scale[1], viewOutline[3] * scale[1] + 1, 0 });
      SketchBlockDefinition block;
      mathPt = (MathPoint)mathUtil.CreatePoint(new double[3] { viewOutline[0] * scale[1], viewOutline[1] * scale[1], 0 });
      block = sktMngr.MakeSketchBlockFromFile(mathPt, @"C:\Solidworks Common\blocks\RIGHT_SIDE_L.SLDBLK", false, (scale[1] - 20) / 1000.0, 0);
      block = sktMngr.MakeSketchBlockFromFile(mathPt, @"C:\Solidworks Common\blocks\RIGHT_SIDE_L.SLDBLK", false, (scale[1] - 20) / 1000.0, 90);
      block = sktMngr.MakeSketchBlockFromFile(mathPt, @"C:\Solidworks Common\blocks\RIGHT_SIDE_L.SLDBLK", false, (scale[1] - 20) / 1000.0, 180);
      block = sktMngr.MakeSketchBlockFromFile(mathPt, @"C:\Solidworks Common\blocks\RIGHT_SIDE_L.SLDBLK", false, (scale[1] - 20) / 1000.0, 270);
      Following are the actual angle generated after the above code:
      90° = 116.62°
      180° = 233.24°
      270° = 349.86°
      Has anyone else encountered this before?
      What am I missing here?
      Regards,
      Joecel
