Does anybody know, how to add extra steel material definitions with their properties to the built in solidworks library ?
Thanks for your help.
Regards
Regards
There are some materials I added directly to the library file in SW, I wanted to avoid going to another 'screen' to select them and they would not be in order anyway. I downloaded this material library from here on the forums and have the original zip file. I have loaded a few of them but I can not vouch for their accuracy in simulations. I did paste these directly into the existing SW library file but I wouldn't recommend the process for just anyone.
You add them to the Custom Materials library, not in Solidworks Materials. The simplest way is to right click a similar material in the SW library, and click Copy, then right click and paste it into your Custom library and edit it as required.
