While working in an assembly I wanted to modify a part and place holes in it using the hole wizard. The feature works fine except for one issue. If I wanted to snap the placement of multiple holes to geometry of another part within the assembly. Only the first hole will snap to a location. The other holes I have to place them close to where I want them, press the escape key and then drag them until they snap to the geometry I would like them associated with. In the past I was able to snap all my hole placements as I was adding them to my part. What has changed to cause this to add steps to doing what should be simple?
That issue popped up with the first versions of SW2015, but was fixed with service pack 1.1. I see your profile says you're using SW2013. Is that still the case?
