4 Replies Latest reply on Jan 29, 2015 8:28 AM by Keith Rice
    Traverse assembly at component level
    Damon Frashure
      I'm trying to make this code segment from the Knowledge Base (below) work in SW2010.  When I paste it in the VBA window I get an error because of an invalid number of arguments.  Can someone explain this?  Basically I am trying to write a macro that will let me traverse an assembly and save each part file with a new {sequential} file name and update the assembly at the end.  Thoughts?
      Option Explicit
      Sub TraverseComponent _
      ( _
          swComp As SldWorks.Component2, _
          nLevel As Long _
          Dim vChildComp                  As Variant
          Dim swChildComp                 As SldWorks.Component2
          Dim swCompConfig                As SldWorks.Configuration
          Dim sPadStr                     As String
          Dim i                           As Long
          For i = 0 To nLevel - 1
              sPadStr = sPadStr + "  "
          Next i
          vChildComp = swComp.GetChildren
          For i = 0 To UBound(vChildComp)
              Set swChildComp = vChildComp(i)
              TraverseComponent swChildComp, nLevel + 1
              Debug.Print sPadStr & swChildComp.Name2 & " <" & swChildComp.ReferencedConfiguration & ">"
          Next i
          Dim swApp                       As SldWorks.SldWorks
          Dim swModel                     As SldWorks.ModelDoc2
          Dim swAssy                      As SldWorks.AssemblyDoc
          Dim swConf                      As SldWorks.configuration
          Dim swRootComp                  As SldWorks.Component2
          Dim bRet                        As Boolean
          Set swModel = swApp.ActiveDoc
          Set swConf = swModel.GetActiveConfiguration
          Set swRootComp = swConf.GetRootComponent3(true)
          Debug.Print "File = " & swModel.GetPathName
          TraverseComponent swRootComp, 1
        • Re: Traverse assembly at component level
          Attilio Colangelo
          Seems like the line continuation character "_" formatting doesn't survive cut and paste. It happens often. Change the first few lines to this:
          Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
          Here is some exciting information on how the line continuation should work
          https://msdn.microsoft.com/en-us/library/ba9sxbw4.aspx
            Keith Rice
            Damon,
            As Attilio pointed out, when the code its pasted in the VB Editor, it brings in some additional characters that cause problems. See the yellow highlight:
            Removing those should be sufficient. However I would also encourage you to check out this blog post, "How to Copy, Clean, & Use API Help Examples" for additional tips related to using API Help examples.
            BUT WAIT!
            If you need to perform a particular task on every component in an assembly (or every component that meets a specific criterion), there is no reason to use that code you pulled from the API Help. There are faster and simpler ways to accomplish the same thing.
            If you don't care about the order in which you traverse, simply use the free macro on my web site "Run code on every part in an assembly" (technically a misnomer -- should read "every component" not "every part").
            If you need to traverse the components in the exact order they are in the feature tree, I can supply you some other code that will do that. The current code you are using won't traverse in order.
            Keith
            SolidWorks API Tutorials
                Damon Frashure
                I'm not worried about the traverse order.  Really all I'm trying to do is write a macro that will take each part in an assembly and change the name while updating the assembly reference (basically just a SaveAs without the save as copy box ticked).  I haven't played with your code yet, but the first one create4d a new part file for each instance it showed up in the assembly.  How will your macro respond to this situation?
                    Keith Rice
                    Damon,
                    The macro I referenced simply demonstrates how to properly traverse an assembly without regard to order. Whatever other functionality or behavior you want will need to be programmed in. You could program it to save every component as a new file or save every unique component as a new file. If you wanted to do the latter, you'd simply need to keep track of the names of the components that have already been saved, minus their instance number.
                    Also, if your only goal is to rename components while preserving references, then the Document Manager API would be more appropriate, though that is a serious step up in complexity and perhaps not worth it if this is just a hobbyist project.
                    Hope this helps! Good luck.
                    Keith
