Hello, anyone experiencing a delay when deleting sketch entities (lines, points, curves, etc.)? I am getting a 16s delay every time I delete something within a sketch. This seems to happen after I open a medium size assembly (244 parts, 49 unique parts, 159 mates) and then I open a single part within the assembly and try to either modify or create a new sketch. The assembly is a sheet metal enclosure with pem fasteners...I removed all external referencing and I'm still having the problem. Tried moving the assembly from the server to my local drive, same problem. It even happens after I start a new part, save it locally, then start sketching. Any suggestions? Thanks! Aron
Version: SW 2015 64-bit SP1.1
OS: Win7 Pro
CPU: Z800 workstation Intel Xeon CPU X5550@2.67GHz (2 processors)
Memory: 24GB
Drive: SSD 107GB free
I traced the problem back to a single part within the assembly that contained a massive sketch (24,000 entities but with no relations). The sketch originated from a circuit board layout designed in EAGLE, exported as a dwg drawing, then imported into SW as a sketch. I used this sketch as a reference to trace the PCB outline and surface mounted component locations and then I suppressed the sketch to lighten the load...but I guess having the sketch suppressed wasn't enough. Once I deleted the massive sketch, the delete delay went away completely. So I would investigate parts that contain any large sketches ( suppressed or not). The part with the massive sketch only had to be open to cause the problem with any other unrelated part I was working with.
