InsertCenterMark2→double Center Mark?
Question asked by Yong Ning on Jan 27, 2015
Latest reply on Jan 27, 2015 by Yong Ning
Follow code run result is double center mark.
4
Dim swView As SldWorks.View
Dim vComps As Variant
Dim vEdges As Variant
    swApp.SetUserPreferenceToggle swUseEnglishLanguage, True
    'Stop
    Set swModel = swApp.ActiveDoc
    Set swView = swSelMgr.GetSelectedObjectsDrawingView2(1, -1)
    swModel.ClearSelection2 True
    vComps = swView.GetVisibleComponents
    Dim i As Integer
    If False = IsEmpty(vComps) Then
        For i = 0 To UBound(vComps)
            vEdges = swView.GetVisibleEntities(vComps(i), swViewEntityType_Edge)
            If False = IsEmpty(vEdges) Then
                Dim swSelData As SldWorks.SelectData
                Dim j As Integer
                Set swSelData = swSelMgr.CreateSelectData
                swSelData.View = swView
                For j = 0 To UBound(vEdges)
                    Dim swEnt As SldWorks.Entity
                    Dim swEdge As SldWorks.Edge
                    Dim swCurve As SldWorks.Curve
                    Set swEdge = vEdges(j)
                    Set swCurve = swEdge.GetCurve
                    If swCurve.IsCircle Then
                        Dim isClosed As Boolean
                        swCurve.GetEndParams 0, 0, isClosed, False
                        If isClosed Then
                            Set swEnt = swEdge
                            swEnt.Select4 True, swSelData
                Next
        Next
    Dim SwDraw As DrawingDoc, SwCenMark As CenterMark
       Set SwDraw = swModel
       Set CenterMark = SwDraw.InsertCenterMark2(swCenterMark_CircularGroup, True)
       'Stop
run code result error ,is double center mark   see arrow
Hope run result see follow picture → single center mark.
