0 Replies Latest reply on Jan 29, 2015 3:10 AM by Yong Ning
    Why don't run InsertHoleTable
    Yong Ning
      2010 SolidWorks API Help - Insert Hole Table Example (VBA)
      http://help.solidworks.com/2010/english/api/sldworksapi/insert_hole_table_example_vb.htm
          Set swModel = swApp.ActiveDoc
          Set swView = swSelMgr.GetSelectedObject5(1)
          vPickPt = swSelMgr.GetSelectionPoint(1)
          Set swHoleTable = swView.InsertHoleTable( _
                              False, _
                              vPickPt(0), vPickPt(1), _
                              swBOMConfigurationAnchor_TopLeft, _
                              ""): Debug.Assert Not swHoleTable Is Nothing
          Set swTable = swHoleTable
      2010 SolidWorks API Help - Change Tags in Hole Table Example (VBA)
      http://help.solidworks.com/2010/english/api/sldworksapi/change_tags_in_hole_table_example_vb.htm
      2010 SolidWorks API Help - Document Properties > Tables > Hole
      http://help.solidworks.com/2010/english/api/swconst/dp_tables-hole.htm
      How to use Hole table with API? | SOLIDWORKS Forums
      https://forum.solidworks.com/thread/64491
      How get ID of line in drawing? | SOLIDWORKS Forums
      https://forum.solidworks.com/thread/52695
      How to use InsertCenterMark2? | SOLIDWORKS Forums
      https://forum.solidworks.com/message/363829#363829
      Private Sub ll()
         Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
            Set SwApp = Application.SldWorks
            Set SwModel = SwApp.ActiveDoc
         Dim SwSelMgr As SelectionMgr
            Set SwSelMgr = SwModel.SelectionManager
         Dim SwDraw As DrawingDoc, SwView As View
            Set SwDraw = SwModel
         Dim SwFeat As Feature, Ss, Pp(1), Rr
            Set SwFeat = SwDraw.FeatureByName("Drawing View10")
            SwFeat.Select True
            Set SwView = SwFeat.GetSpecificFeature2
            Debug.Print SwView.ScaleDecimal
            kk = SwView.ScaleRatio
            Ss = SwView.Position
            Rr = 300 / 2 / 1000
            Pp(0) = Ss(0) + Rr * SwView.ScaleDecimal
            Pp(1) = Ss(1)
            With SwModel.Extension
               .SelectByID2 "", "EDGE", Pp(0), Pp(1), 0, True, 0, Nothing, 0
               .SelectByID2 "", "FACE", Pp(0) + 10 * SwView.ScaleDecimal, Pp(1), 0, True, 1, Nothing, 0
            End With
            SwView.InsertHoleTable False, 0.1, 0.1, 3, "D:\h.SldHolTbt"
            Stop
