I have a belt sketch I've extruded into a belt and then placed 310 holes using curved pattern spacing them at 30mm apart along the length of the belt. in the assembly i'm placing a nest sub assembly on one hole, then using a feature driven pattern to place one on the remaining 309. everything looks great except when i look in the feature tree it lists 1241 nest sub assemblies. any idea why it would place more than one nest assembly per hole? or is there something else going on here? i wouldn't mind it except it really bogs down the assembly as you can imagine.
fyi i'm running SW2013 SP5.0
Ok I was able to get it, for some reason it was doing it because I was running the Feature driven pattern in the main assembly and not a sub assembly of just the belt and a nest. even though the belt and nest were in the same assembly before, they needed to be in their own sub assembly.
