0 Replies Latest reply on Jan 23, 2015 10:36 AM by Drew Wiggins
    How do we know what the revision of the drawing built a specific ePDM BOM?
    Drew Wiggins
      Using the API, every BOM has a version of 1, linked to the drawing file (but without knowing the revision of the drawing).  Is this possible?
      Here is the P.O.C. code snippet I'm currently working with:
      Public Function TryGetBom(Of _EdmBomType As IEdmBom)(ByRef bom As _EdmBomType, ByRef exception As Exception) As Boolean
           Dim derivedBoms As EdmBomInfo() = Nothing
           Try
              Dim bomMgr As IEdmBomMgr = Nothing
           If Vault.TryCreateUtility(EdmUtility.EdmUtil_BomMgr, bomMgr, exception) = False Then
              Return False
           If TryGetDerivedBoms(derivedBoms, exception) = False Then
              Return False
           For bomIndex As Integer = 0 To derivedBoms.Length - 1
                Dim id As Integer = derivedBoms(bomIndex).mlBomID
                'Dim bom As IEdmBom = Nothing
                Dim versions As EdmBomVersion() = Nothing
                If Vault.TryGetObject(EdmObjectType.EdmObject_BOM, id, bom, exception) = False Then
                   Continue For
                   End
                If
                     bom.GetVersions(versions)
                For versionIndex As Integer = 0 To versions.Length - 1
                     Console.WriteLine("{0} - {1}) {2} - {3}", bom.Name, versionIndex, versions(versionIndex).mbsTag, versions(versionIndex).mlVersion)
                     Dim bomLayouts As EdmBomLayout() = Nothing
                               bomMgr.GetBomLayouts(bomLayouts)
                     For bomLayoutIndex As Integer = 0 To bomLayouts.Length - 1
                          Dim bomView As IEdmBomView = Nothing
                          Try
                                              bomView = File.GetComputedBOM(bomLayouts(bomLayoutIndex).mbsLayoutName, versions(versionIndex).mlVersion, "", EdmLib.EdmBomFlag.EdmBf_AsBuilt)
                          Catch ex As Exception
                             Continue For
                          End Try
                     Next
                Next
           Next
           Return False
                exception = ex
                Return False
           End Try
      End Function
      Thanks!
