Hi, guys - I'm hoping one of you experts can help me. I draw parts for Outdoor Lighting fixtures, have done some fancy scrolled extrude cut and extrude boss parts, with patterning, etc.
But now I'm tasked with drawing a large (about 14" wide) Bronze Eagle, with his curved wings spread. They need me to draw it so a Mold pattern can be made from the drawing.
It has 3 layers of feathers on both surfaces of each wing. - I did one layer, on one side, extruding from original surface, to keep it a "part"
Then I figured before I get too far, I better try to "flex" (curve) the wing.
Set all the parameters, and click the check mark - And my computer just runs forever. Blue circle of "wait", FOREVER. (Well, 15-20 min., before I closed Solidworks and went back)
Tried this 3 times.
Only strange thing, was when I clicked the part for the top box (part to be flexed), instead of "Eagle Wing", it said "Chamfer"
I did do a number of chamfers, on each "feather" for the row that I completed. But the part name is "Eagle Wing 4-Assem."
I tried to bend part of the wing, moving the "Plane 2" 2.65in to the left, and bending the rest of it to a radius of 5 in.
Maybe one of you can try to use the "bending" feature of Flex?
While the name of your part is "Eagle Wing 4-Assem", the name of the body is usually the last feature applied to it. The flex tool is working on a body, which is what's identified in the box.
As for you problem, I'd suggest creating the body of the wing as a loft, with the curve included, and then put your feathers in. I suspect that SolidWorks is puking on all the edges/features/data when trying to squish/stretch them. Just a guess on my part.
