move/copy
Question asked by Timothy Luchini on Jan 22, 2015
I am trying to write a macro in Solidworks to create an array of 100 randomly aligned disks. After I extrude one disk, I am able to use Body-Move/Copy to translate the disks in 3D to points read from a file. Once the disks have been moved I cannot rotate them around their center-point. I also cannot move and rotate the disks in the same step. My most basic question is after I have made my 100 disks how do I select the move/copy steps to then rotate the disks.
My macro is as follows:
' Macro To Read in Random Centerpoints for Circle Plate Geometries by luchinit
' reminder to change values of square, files locations,
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.NewDocument("C:\ProgramData\SolidWorks\SolidWorks 2011\templates\Part.prtdot", 0, 0, 0)
swApp.ActivateDoc2 "Part1", False, longstatus
Set Part = swApp.ActiveDoc
Dim myModelView As Object
Set myModelView = Part.ActiveView
myModelView.FrameState = swWindowState_e.swWindowMaximized
Part.WindowRedraw
Part.WindowRedraw
swApp.ActiveDoc.ActiveView.FrameState = 1
Dim skPoint As Object
Dim skSegment As Object
Dim Line As Object
' Dim myModelView As Object
Dim vSkLines As Variant
' REMINDER TO UPDATE: set dimentions of square in um
square = 103.0465097
' REMINDER TO UPDATE: Plate Radius
Srad = 2
' EMINDER TO UPDATE: Plate Thickness
Thick = 0.1
' REMINDER TO UPDATE: Circle Radius
CircRad = 2.6
' REMINDER TO UPDATE: read file from this location for sphere center point generation
Open "C:\Users\VolumeFractionGeometries\100Particles\Spheres\3umParticle_20FiberVF_5.8PartVF.txt" For Input As #1
Open "C:\Users\VolumeFractionGeometries\100Particles\Spheres\3umParticle_20FiberVF_5.8PartVF.txt" For Input As #3
' REMINDER TO UPDATE: read file from this location for cylinder center point generation
Open "C:\Users\VolumeFractionGeometries\100Particles\EnergyVariationParticleGeometries\20h1e2.txt" For Input As #2
boolstatus = Part.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
Part.ClearSelection2 True
Set skSegment = Part.SketchManager.CreateCircle(0#, 0#, 0#, 0, Srad, 0#)
Part.SketchManager.InsertSketch True
Part.ShowNamedView2 "*Trimetric", 8
boolstatus = Part.Extension.SelectByID2("Sketch1", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
Dim myFeature As Object
Set myFeature = Part.FeatureManager.FeatureExtrusion2(True, False, False, 0, 0, Thick, Srad, False, False, False, False, 0, 0, False, False, False, False, True, True, True, 0, 0, False)
Part.SelectionManager.EnableContourSelection = False
' Sketch and extrude plates
Do While Not EOF(1)
Input #1, X, Y, Z
'boolstatus = Part.Extension.SelectByID2("Boss-Extrude1", "SOLIDBODY", 0, 0, 0, True, 0, Nothing, 0)
'Part.ClearSelection2 True
'boolstatus = Part.Extension.SelectByID2("Boss-Extrude1", "SOLIDBODY", X, Y, Z, True, 1, Nothing, 0)
'Set myFeature = Part.FeatureManager.InsertMoveCopyBody2(X, Y, Z, 0, X, Y, Z, 0, 5.75958653, 0.34906585, True, 1)
boolstatus = Part.Extension.SelectByID2("Boss-Extrude1", "SOLIDBODY", 0, 0, 0, False, 1, Nothing, 0)
Set myFeature = Part.FeatureManager.InsertMoveCopyBody2(X, Y, Z, 0, 0, 0, 0, 0, 0, 0, True, 1)
Loop
Close #1
' Rotate Plates
Do While Not EOF(3)
Input #1, X, Y, Z
Input #3, A, B, C
boolstatus = Part.Extension.SelectByID2("Boss-Extrude1[]", "SOLIDBODY", X, Y, Z, False, 1, Nothing, 0)
Set myFeature = Part.FeatureManager.InsertMoveCopyBody2(0, 0, 0, 0, X, Y, Z, A, B, C, False, 1)
Loop
Close #1
Close #3
