I'm having issues with sheet metal flat patterns not showing correctly. I attached an example of a liner design, with a variety of cuts and holes. The issue arises when the filets on the terminal cuts are suppressed or deleted. After that the flat pattern doesn't show any of the hole wizard holes or the TC hole, but still shows the square terminal cuts. Usually the radius is done as part of the sketch for the cuts, but I did it as a fillet feature for ease of suppression to troubleshoot. When done in the sketch it still causes the flat to be incorrect. I'm looking for assistance as to why this is happening. I'm using SW 2014 service pack 1. Thank you.
I think this may be a bug as the fillet is in no way attached to the features below it and they aren't even being suppressed. I was able to replicate the problem in SW2015 SP1.1.
If you're on subscription, I'd report this to your VAR.
Now that I've said that, I'm sure someone will step in with the solution. Much like how the waitress doesn't ask you how your food is until you have a mouthful of it...
