8 Replies Latest reply on Jan 22, 2015 2:01 PM by Stephen King
    Multi-sheet linking sheet names
    Stephen King
      What I've been trying to do is to create a multi-sheet drawing template and use $PRP:"SW-SHEET (SHEET NAME)"
      So, on my first sheet, I add the custom property $PRP:"SW-SHEET and position it on the sheet where I want it.
      Next, I go and rename my first tab "say.. I rename it BOM. Then save the template and the format. and close.
      Next, I open up that template, then click the tab new sheet, and open up that template, when I rename that sheet "say.. section view
      section view does not populate the drawing. if I create a text and link it, it will show section view.
      It loses its link, when I add sheet. I have to recreate it for each sheet.1.JPG
      2.JPG3.JPGit should say Sheet 10
      Plan of Die and Plan of Punch, I had to recreate. The problems is... I need about 25 sheets names per sheet size.
      E,D,C,B,A and a few custom sheets
      I would rather, have the sheet name populate as needed. Rather than create a multi-sheet template manually.
