Am I able to plot of contact forces between gears only using the gear mate? I'm fairly new to solidworks and would prefer avoiding setting up a "teethed" gear. If you need more information to answer just let me know! Thanks
Gear forces are very easy to calculate without sophisticated software. Gear stresses are a little more involved, but they are still well understood. Post a schematic of you gear train and I'll tell you the forces.
Within the setup I have a two gears with a pre-compressed spring attached to fixed points of each gear. Rotation of the of this system would generally be dictated by a displacement of a rack but I just set specific rotation for one of the gears to run through in motion analysis. Since the pre-comressed spring extends over this period the force drops but due to where they are attached to the gear the moment arm increases. My goal is to determine the force the top gear would apply to the rack or simply the torque the spring creates on each gear.
*the spring remains in compression throughout the motion
I know I might have not done the best job describing that but I've attached two images and hopefully it will make sense.
I would have attached the file but I’m not entirely sure how.
Thanks!
This is more complicated than some standard torque in/out gear train. So, maybe not a silly use of sophisticated software like a claimed. Still, I said I could solve it, so here is the solution. You might want to leave this question up until a motion expert posts the solution you are looking for.
I made up the parameters--you will need to supply them to get your answer. Cool problem.
Edit: Fixed a couple of problems.
Hi Even,
Motion is a rigid body mechanics program - depending on how you set up the supports for the gears and how they interact the spring won't do a thing in terms of transmitting force depending on how the rotational degree of freedom is handle - like say a revolute joint - its infinitely stiff. To set this up so that the gear "floats" requires using bushings If you want some stiffness) or releasing the appropriate degree of freedom. Then the spring can actually transmit forces to the other entities.
You can get torque from motion for disc like geometries for gears. Pick you moment arm for force if you like then.
