Is there a simpler method for this? I want to draw a line that isn't on a single XY YZ or ZX plane. So far I've been using construction lines, one on each plan, to create a point where I want my line to end. I then draw my line. Result.... too many constructions lines. Is there an easier or alternative way?
Pic shows my three construction lines and then my final line links to the end.
Like Jeremy said, one way is to use dimensions. I think you'd have to dimension to planes, such as the Front, Top, and Right.
Another method is to draw the line ending anywhere, then select the endpoint and you can enter the coordinates for it. This will move the endpoint to where you want it but you are left with an unconstrained line, so you'd probably end up adding dimensions anyway.
