1 Reply Latest reply on Jan 21, 2015 10:23 AM by Keith Rice
    How to get  quantity in Hole Table?
    Yong Ning
      Follow code can get TableAnnotations
      Hope get quantity . see picture?
      Private Sub del20150121()
         Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2, SwDraw As DrawingDoc
            Set SwApp = Application.SldWorks
            Set SwModel = SwApp.ActiveDoc
            Set SwDraw = SwModel
         Dim SwFeat As Feature
            Set SwFeat = SwDraw.FeatureByName("HTable")
         Dim hTable As HoleTable, SwTabAnn As TableAnnotation
            Set hTable = SwFeat.GetSpecificFeature2
            Stop
            With hTable
               Debug.Print .GetTableAnnotationCount
               Set SwTabAnn = .GetTableAnnotations(0)
      '''' How to get quantity in Hole Table?
            End With
            Stop
        • Re: How to get  quantity in Hole Table?
          Keith Rice
          Yong,
          Simply traverse all cells in the hole table until you find the one with text equal to "Quantity", then get the cell directly below it.
              For intCol = 0 To SwTabAnn.ColumnCount - 1
                  For intRow = 0 To SwTabAnn.RowCount - 1
                      If SwTabAnn.Text(intRow, intCol) = "QUANTITY" Then
                          Debug.Print SwTabAnn.Text(intRow + 1, intCol)
                      End if
                  Next intRow
              Next intCol
          You might also add "Option Compare Text" at the top of your code so that text comparison is always case-insensitive.
          Keith
          SolidWorks API Training
