I want to be able to create 36 different camera angle renders of my model (one image for every 10 degrees) starting with the profile view and incrementally moving around the product every 10 degrees until it makes a full 360.
How would I set this up and is it possible for it to automatically render and save an image file for each camera angle?
Would I even need Composer to do this or could it be done with some other add-on?
Many thanks!
David
David,
If you are already using Solidworks you can just create camera views in there to render. Just go to view>lights and cameras>create camera view. You can then name the camera whatever you would prefer. You can then schedule your renders in your render tools.
Composer can achieve the same but will not give you photo quality renders as in Solidworks. In composer you would create 36 views and then export your views in the High Resolution workshop. I am fairly certain you can't batch export in Technical Illustration workshop so you would have to use Hi Resolution to batch.
Hope this helps some.
Cheers,
Derek
