Hello, I am having trouble with this, as the tittle says the cutlist has a body duplicated, not sure why but I would like to fix it, I would like to make clear that it is THE SAME body, has the same dimensions and the same material, and even when there is 2 different bodies in the cutlist if I delete one both are gone from it.
Can you post the part so someone can take a look at it? Click on the text "Use advanced editor" at top right, then there will be a link at lower right to attach files.
