When I select a sketch entity, i.e. line/slot, then draw the entity on the plane, it does not keep the entity active or in chain selection. What do i have to change so I don't have to keep selecting recent command? Oh, this is in click click mode not click drag just to be clear.
Hi Corey,
Make sure you have the Single Command per Pick option turned off. See the third option in this help topic:
2014 SOLIDWORKS Help - System Options - General
I hope this helps,
Jim
