AAAbdulaziz Abutunis16/01/2015
Hi All,
I am seeking you advice in loft issue. I am importing a set of data of airfoils. The lowest airfoil is curve so it is attached to the hub ( cylinder surface). The problem is that the the Move Entities is not active so i manipulated them in Matlab but I could not use the Lofted Boss/Base function. The error I have is " the end section for loft must be either planar or 3D faces or surface. A3D section that does not bounded a face or surface cannot be used as an end section. I do not want to do surface lofting because i want the blade to be solid.
Thank you,
Aziz
