10 Replies Latest reply on May 7, 2015 9:54 AM by Dan Sikorski
    Extract custom properties using Get:All
    Mark Coville
      I know how to get all custom properties my question in how do I pull out certain custom properties? I don't want to just export all of them, only certain ones. Should I just be using Get4?
        • Re: Extract custom properties using Get:All
          Daniel Andersson
          If you know the name of the property you could simply use the Get5 method (SolidWorks 2014).
          Otherwise you could still get all properties and then loop thru all...
          The reason for choosing which one is based on your needs. E.g Get5 requires you to know exactly the property name.
          But if you choose to get all and loop, you could do operations with strings to sort out if the property is intresting or not.. E.g you want all properties that starts with A...
          Here is an example from the API reference. The example shows how to use the different methods for the CustomPropertyManager.
              Mark Coville
              So using get4 or get5 would probably be the same # of lines as using getall and looping thru for certain properties?
                  Daniel Andersson
                  In general it is not possible to make that conclusion. Since it is dependent on what you will do with the properties and the data.
                  Let's say you have 30 properties. To get all data and do something with it would be quite many rows of code, if using the Get5 method and process each property. GetAll2 is way more efficient since you could easily loop thru all data.
                  Another scenario is if you have two properties as date format. You know the name if the properties and want the code to just get the values, remove them and add them again with the format as text. Then it is better to directly target them with Get5.
                      Mark Coville
                      Ok so with the 30 properties scenario what would the loop look like using getall2?
                          Daniel Andersson
                          Here is a simple example that will print all common (not configuration specific) custom properties to the immediate windows in VBA.
                          Dim swExt As SldWorks.ModelDocExtension
                          Dim swCustPropMgr As SldWorks.CustomPropertyManager
                          Set swModel = swApp.ActiveDoc
                          Set swExt = swModel.Extension
                          Set swCustPropMgr = swExt.CustomPropertyManager("")
                          Dim vPropNames As Variant
                          Dim vPropTypes As Variant
                          Dim vPropValues As Variant
                          Dim vResolved As Variant
                          Dim iRetVal As Integer
                          iRetVal = swCustPropMgr.GetAll2(vPropNames, vPropTypes, vPropValues, vResolved)
                          For i = 0 To UBound(vPropNames)
                              Debug.Print "Name:     " & vPropNames(i)
                              Debug.Print "Type:     " & vPropTypes(i)
                              Debug.Print "Values:   " & vPropValues(i)
                              Debug.Print "Resolved: " & vResolved(i)
                              Debug.Print ""
                              'Etc etc... do what you want here with each property.
                          Next
                          P.s iRetVal could be used to determine for how long the loop should keep going. I used Ubound of old habit.
                              Mark Coville
                              Ok so at 'Etc etc... do what you want here with each property. is what I don't know how to do.
                              ie I want to print the values of Description, Number, PartNumber, Material, etc, etc. How do I print those without going
                              if vpropName(i) = "Description" then
                              debug.print vResolved(i)
                              end if
                              If I have 30 properties and I have to do this 30 times would it not be just as easy to say
                              boolstatus = swCPM.get4 ("Description", Type, valout, DescriptionRetVal)
                              Is there a quicker way to loop through all the variants?
                                  Daniel Andersson
                                  To make it easier you could make an array that contains the names of the properties you want to get. This array could then be used in two different concepts. Both concepts will reduce the number of IF statements.
                                  First concept.
                                  Here is the idea that you add another loop in the loop for all properties. In this loop you will check the custom property at position i in the variant array and if it matches a value in your array it is printed.
                                  Second concept.
                                  You loop thru your array and use the Get5 get the data you want. One positive thing with this code is that you could handle exceptions if the property does not exist in a easy way. Since Get5 also returns a value to determine the output from the method.
                                  Both concepts will do the job and can be extended to handle exceptions.
                                  I recommend that you start with a method that you are comfortable with, since I do not know if you are new to coding or not.
                                  If you are new, do not let the efforts to find the best and optimal code kill the joy.
                                      Daniel Andersson
                                      Code examples [VBA]
                                      First concept:
                                      Dim sPrint(2) As String
                                      sPrint(0) = "Description"
                                      sPrint(1) = "PartNo"
                                      sPrint(2) = "Material" 'Add further positions in the array if needed. Do not forget to change the dimension of the array sPrint
                                          For j = 0 To UBound(sPrint)
                                              If vPropNames(i) = sPrint(j) Then
                                                  Debug.Print ""
                                          Next
                                      Next
                                      Second concept:
                                      Dim sPropValue As String
                                      Dim sResVal As String
                                      Dim bResolved As Boolean
                                      For i = 0 To UBound(sPrint)
                                          iRetVal = swCustPropMgr.Get5(sPrint(i), True, sPropValue, sResVal, bResolved)
                                           'Options of the Get5 method might be needed to be reconsidered.
                                          Debug.Print "Name:       " & sPrint(i)
                                          Debug.Print "Values:      " & sPropValue
                                          Debug.Print "ResolvedVal: " & sResVal
                                          Debug.Print "WasResolved: " & bResolved
                                          'Etc etc... do what you want here with property.
                                      Next
