Is there a method of checking in multiple none-SolidWorks files in a single process? We use both AutoCAD and SolidWorks, so I export SolidWorks drawings into AutoCAD, then additionally check in the AutoCAD drawings. This becomes tedious, as I use the "Check in from disk" command in the SolidWorks File Explorer, and it only allows me to check in one file at a time. Is there a better way?
You can use the bulk checkin in the vault admin tool.
