Thicken one surface, alters the wall thickness of other in contact.
Question asked by Victor Ascencao on Jan 15, 2015
Latest reply on Jan 15, 2015 by Ingvar Magnusson
Hi guys, I'm designing a plastic box so I created the body of it as a solid and then shell it to 1.6 mm perfectly, after that and because is easier in this part I created a planar surface from the inner border of the top box wall and trim it as I need to create a variable width top form.
      The idea is to thicken it to merge with the vertical wall and either merge the result or combine the 2 solids after that (very normal thing to do)
      I tried one and the other and in both cases the result is the damage of the already thick vertical wall and strangely very far away from the top.
      I attached a video that shows what happen. Im working with 2015 and tried it on my base machine and on my laptop, the results are the same.  It seems to be a bug, any ideas?
Thank you in advance
Victor Ascencao
