Very much like a barber pole, how do render four equally-spaced slots in a tube. A helix only seems to work for one since its start point seems to be random. Tried a spline but am having trouble keeping the cut oriented properly as it moves down the tube.
If you are able to model one of the slots then you can do a circular pattern to get the other 3. By the way, you can set the helix start angle when you are creating the helix.
