Hi everybody,
My question is:
I have the frequency spectrum of a pressure signal. Spectrum is composed by Frequency, Magnitude and Phase, but, if I want to put it into Solidworks (during the Harmonic Analysis), when I change the function curve of my signal, I've noticed the lack of the input "phase"; there is only the column of Frequency and of the Magnitude. So, how do I do to upload in SolidWorks my Frequency Spectrum?
could you show what curves you're trying to enter and a reference for the type of analysis you're trying to do?
2015 SOLIDWORKS Help - Analysis Procedure - Harmonic
2015 SOLIDWORKS Help - Harmonic Analysis
Describe how the equations works and what is happening behind the scenes. Phase can be input when you input your curve but i'm not sure I understand exactly what your input is and how to use it.
I'd also recommend checking the swx KB.
