i have a question about this part. I want to change the hex nut to be .25-20. But, this nut is a part of the weldment. Is there a way to change this nut and have it stay accurate in the assembly?
- RMB on the nut or in the feature-tree
- List External Refs
- Change the part in Configuration Name
If your size isn't in the list (not yet made a configuration of it), you should place the nut in an assembly and pick the right size. (not in the weldment).
This will make a new configuration and now you can change it in the weldment.
There is a Replace Component function in Assemblies, but I'm not aware of a similar function for Parts inserted into another Part. You can change a part to a different configuration, but to change to a completely different Part I believe you'll need to delete that Nut from the Part and insert the correct size.
