I'm having trouble with a sheetmetal part. I've created a multi-flanged curve, but I would like to eliminate three flanges and connect the remaining at a 90 degree angle? If I delete on flange, the rest of the model disappears. I was in boundary-cut and it looked like I was in the right place, but I'm a little lost on how to finish the cut? Any help would be appreciated.
You'd end up creating a multibody part, which you'd then need to use the move/copy bodies command and a combine feature as well. I think you'd be better off deleting the unwanted bends, then edit the top bend to meet your needs.
If you post your part, and tell us what version of SolidWorks you're on, someone can probably help you out.
