I want the results to use decimal format of numbers for stress, displacement etc.
Currently, it shows in scientific number format.
If you're using SimulationXpress, you can't change the output. If you're using the Simulation Add-in, right click on Stress1 and select 'Edit Definition'. Select the 'Chart Options' tab and change scientific to floating.
