3 Replies Latest reply on Jan 20, 2015 5:58 PM by Mark Olsen
    Component is selected, but doesn't become visible
    Mark Olsen
      I've been working on code to show all envelopes for selected sub-assemblies.  This code gets the sub-components that are envelopes, but the line to make them visible doesn't work.  Anyone have an idea why?
      Dim swPart As SldWorks.ModelDoc2
      Dim swSelMgr As SelectionMgr
      Dim myComp As Object
      Dim mySubPart As Object
      Dim boolstatus As Boolean
      Dim c As Integer
      Dim i As Integer
      Set swPart = swApp.ActiveDoc
      Set swSelMgr = swPart.SelectionManager
      c = swSelMgr.GetSelectedObjectCount
      For i = 1 To c
          Set myComp = swSelMgr.GetSelectedObject6(i, -1)
          Set mySubPart = myComp.GetModelDoc2
          If mySubPart.GetType = 2 Then
                  Dim swSubAssy As SldWorks.AssemblyDoc
                  Dim vComps As Variant
                  Dim j As Integer
                  Set swSubAssy = mySubPart
                  vComps = swSubAssy.GetComponents(False)
                  For j = 0 To UBound(vComps)
                      Set swComp = vComps(j)
                      Debug.Print swComp.Visible
                      Debug.Print swComp.IsEnvelope
                      If swComp.IsEnvelope Then swComp.Visible = True
                  Next
      Next
      Mark
        • Re: Component is selected, but doesn't become visible
          Keith Rice
          Mark,
          The problem is that you are making the component in the underlying assembly visible, not the active assembly. This is because IComponent2::GetModelDoc2 returns the underlying model document. So what you need to do is bring the component pointer from the underlying context to the active model context. This is accomplished using IComponent2::GetCorresponding. The following code gets an arbitrary features in the component, brings it into the active model context, and then gets the component:
          Set swFeat = swChildComp.FirstFeature
          Set swFeat = swComp.GetCorresponding(swFeat)
          Set swChildComp = swFeat.GetComponent
          Here is the full code:
          Dim swChildComp As SldWorks.Component2
          Dim swCompModel As SldWorks.ModelDoc2
          Dim swCompAssy As SldWorks.AssemblyDoc
          Dim swFeat As SldWorks.Entity
          Dim i As Integer, j As Integer
              Set swModel = swApp.ActiveDoc
              For i = 1 To swSelMgr.GetSelectedObjectCount
                  If swSelMgr.GetSelectedObjectType3(i, -1) = swSelCOMPONENTS Then
                      Set swComp = swSelMgr.GetSelectedObject6(i, -1)
                      Set swCompModel = swComp.GetModelDoc2
                      If swCompModel.GetType = swDocASSEMBLY Then
                          Set swCompAssy = swCompModel
                          vComps = swCompAssy.GetComponents(False)
                          If IsEmpty(vComps) = False Then
                                  Set swChildComp = vComps(j)
                                  If swChildComp.IsEnvelope Then
                                      swChildComp.Visible = True
                              Next
              Next
          Keith
          SolidWorks API Training
              Mark Olsen
              Works perfectly.  Thanks for your help.
              Mark
                Mark Olsen
                Well, I spoke too soon.  The macro from Keith works only as long as there are no configurations in the component, or the 'in-use' component matches the 'referenced' component in the assembly.  I modified the macro as follows (added lines in bold):
                                            Dim strOrigConfig As String
                                            strOrigConfig = swComp.ReferencedConfiguration
                                            Dim strNewConfig As String
                                            strNewConfig = swChildComp.ReferencedConfiguration
                                            swComp.ReferencedConfiguration = strNewConfig
                                            swComp.ReferencedConfiguration = strOrigConfig
                                    Next
                    Next
                Basically, it now gets both the in use and referenced configuration names, changes the component to the 'in use' configuration, makes the sub component (the envelope) visible, then changes the component back to the 'referenced' configuration.  Kind of a klunky workaround, but it seems to work.
                Mark
