Hi all,
Does anyone have any tips or tricks for performing a grid convergence study in Flow Simulation? I need to try to determine the grid convergence index (GCI) for my simulation. It seems that to do it right, I have to disable all of the automatic settings. I have an airflow problem where I have set up the following parameters in the manual mesh settings:
Case | 1 | 2 | 3 | 4 | 5 | 6 |
Nx | 70 | 140 | 168 | 202 | 242 | 280 |
Ny | 18 | 36 | 43 | 52 | 62 | 72 |
Nz | 22 | 44 | 53 | 63 | 76 | 88 |
Total Cells | 27,720 | 221,760 | 383,201 | 662,172 | 1,144,233 | 1,774,080 |
However, the total cell count never works out to those numbers due to some of the mesh refinements that occur, such as finer mesh in corners. I solved steady-state simulations for each case, using global goals for average static pressure, turb dissipation, turb energy, Vx, Vy, Vz, and Mass of Fluid. I left all of the convergence criteria set to auto. For a grid study, would it be better for me to manually set the convergence criteria so each simulation solves to the same level of accuracy? Or are the automatic criteria good enough?
After all simulations finished, I compared Velocity at several points (using point parameters) and plotted the values from each case. What I am finding is that the values don't seem to be converging, and in many cases are oscillating as much as 20% from one case to the next even at the highest mesh levels used so far.
The room I am simulating is 36' long x 9 ft wide x 8 ft high, and the total flow rate is less than 2,000 cfm (see attached model). Should I really need more than 1/2-million cells in a room of that size?
The next steps I need to accomplish are to perform a time-step sensitivity study, then run a transient simulation and try to achieve a time-accurate gas decay solution that I can compare to measured data. Any help is appreciated!
can you define how you want to define your GCI?
a few things i'm not following:
1. in your table, you say that the cell count doesn't work out to what is in the table because of refinements. what is the number in the table? the basic mesh? does having more or less cells cause an issue with the way you are defining the GCI?
2."...set the convergence criteria...solves with the same level of accuracy" what do you mean here? you could manually stop the solution at a certain point, number of iterations or some % of the goal but i'm not sure what you are looking to gain with respect to accuracy. it could still be on the high or low side.
3. regarding oscillation, are you talking about the goals plots or are you talking about the results between studies? ie 1 to 2, 2 to 3 and then 3 to 4?
