I'm having problems to create sections views. I'm trying to exclude a rib from being cut but I can't select the component I don't want to cut. When I try to select it, the whole part file is selected and not the component.
PS: I've found this method but it can't help me: http://www.javelin-tech.com/newsletter/tech_old/2007/december/article_isfastener.htm
Could someone help me? Thank you
Marcia,
You can exclude features or components to be excluded from sectioning. Simple Right-Click on the Sectioned View, select Properties, and activate the tab Section Scope, In the selection field, select the feature on screen. If you are unable to select the feature on screen, go to the FeatureManager and browse through the features of the components in the Drawing Views. This will make the selection of features a lot easier. I hope this helps!
