Hi All, Does anyone know if the SolidWorks CSWP exam uses one consistent model or are the multiple models an exam taker could possibly be presented with? I have been working with the sample exam and they show this model:
Can anyone who has taken the exam tell me if this is the model I will be presented with when taking the first segment of the CSWP exam?
Hi Jeff
It is nearly 4 years now since I did the CSWP exams. If that is the model from the sample exam then it more than likely not show up in the actual exam. From memory there will be a mixture of models that you create from scratch and models that you download and modify. There will up to around 20 questions in an exam with 4 to 5 questions per model that you will create / modify. Make sure to read the questions carefully as sometimes there is something that you could miss in the question that could give you a wrong answer.
If you have a dual monitor setup it will help to be able to view the question on one monitor while modelling in SW on the other.
