FAN - inlet pressure dependency on volume flow rate
Question asked by Teresa Coronado on Jan 12, 2015
Latest reply on Jul 16, 2016 by Will Griffiths
Hello everybody,
Is it possible to define the environmental pressure at the inlet of a fan as a function of a goal?
If you use an external inlet fan and you click on “Thermodynamic parameters” - “Dependency”, you just have two options: “Constant” or “Formula definition”, but if you use “Formula definition” you can’t choose a goal as a parameter…
I want to impose the drop pressure at the inlet of the fan as a function of the volume flow rate through that fan.
Thank you in advanced,
Best regards
Teresa
