15 Replies Latest reply on Jan 15, 2015 9:44 AM by Kelson Lachance
    Want to count colour in a Saved out Bitmap
    Kelson Lachance
      I am still using the VB editor that came with Solidworks.
      I think I don't have the correct reference libraries.
      Just trying to save out a bitmap and count the number of pixels of a certain color.  This was the start; but it doesn't recognize the Bitmap calls?
      Dim swApp As Object
      Option Explicit
      ' Dim swApp As SldWorks.SldWorks
      Dim returnVal As Boolean
      Dim fileName As String
          Set swModel = swApp.ActiveDoc
          fileName = "c:\temp\cstick.bmp"
          ' Save as bitmap and use current window size
          returnVal = swModel.SaveBMP(fileName, 0, 0)
          getAverageColor ("c:\temp\cstick.bmp")
      Private Function getAverageColor(ByVal imageFilePath As String)
          Dim bmp As Bitmap
          Dim totalR As Integer
          Dim totalG As Integer
          Dim totalB As Integer
          Dim x As Integer
          Dim y As Integer
          Dim pixel As ColorTable
          Dim totalPixels As Integer
          Dim averageR As Integer
          Dim averageg As Integer
          Dim averageb As Integer
          'Set bmp = Bitmap(imageFilePath)
          For x = 0 To bmp.Width - 1
              For y = 0 To bmp.Height - 1
                  pixel = bmp.GetPixel(x, y)
                  totalR = pixel.R
                  totalG = pixel.G
                  totalB = pixel.B
              Next
          Next
          totalPixels = bmp.Height * bmp.Width
          averageR = totalR \ totalPixels
          averageg = totalG \ totalPixels
          averageb = totalB \ totalPixels
          Debug.Print averageR
          Debug.Print averageg
          Debug.Print averageb
          'Return Color.FromArgb(averageR, averageg, averageb)
      End Function
        • Re: Want to count colour in a Saved out Bitmap
          Daniel Andersson
          Looks like you are trying to do things that is possible in VB/C++/C#.
          I hope that someone comes to prove me wrong, but this is my experience so far...
          The GetPixel method in System.Drawing is not exposed in VBA. The methods you are trying to use is available in VB or C++/C#. If you press F2 you will see the exposed methods and objects for the current loaded references in the VBA editor.
          I was facing a similar issue in the past and found no better way than make a small application in VB Express that gave me what I needed in that case.
          You could also look into to use ImageMagic dlls.
          I have also been trying to get my head to figure out how to use the GDI+, so far this is what I got... for some reasons the RGB values do not match properly.
          It returns RGB(0,242,0) when it should be RGB(255,242,0) or... RGB(0,1,255) when it should be RGB(255,0,255). Not sure what this is due to.
          I have also looked around but not figured out how to instantiate a Color object in VBA.
          Perhaps this could give you a start to something that works out in the end... It would also be much better from a performance point of view to use LockBits, but I'm not sure if that is possible with VBA.
          Here is the documentation for GDI+ Flat API
          You could try to ask this question at stackoverflow.com since it is VBA specific and not related to SolidWorks.
          Private Declare Function GdiplusStartup Lib "gdiplus" (token As Long, inputbuf As GdiplusStartupInput, Optional ByVal outputbuf As Long = 0) As Long
          Private Declare Function GdipCreateBitmapFromFile Lib "gdiplus" (ByVal filename As Long, bitmap As Long) As Long
          Private Declare Function GdipCreateHBITMAPFromBitmap Lib "gdiplus" (ByVal bitmap As Long, hbmReturn As Long, ByVal background As Long) As Long
          Private Declare Function GdipBitmapGetPixel Lib "gdiplus" (ByVal bitmap As Long, ByVal x As Long, ByVal y As Long, color As Long) As Long
          Private Declare Function GdipDisposeImage Lib "gdiplus" (ByVal image As Long) As Long
          Private Declare Function GdiplusShutdown Lib "gdiplus" (ByVal token As Long) As Long
          Private Declare Function GdipGetImageHeight Lib "gdiplus" (ByVal image As Long, Height As Long) As Long
          Private Declare Function GdipGetImageWidth Lib "gdiplus" (ByVal image As Long, Width As Long) As Long
          Option Explicit
          'Declare a UDT to store the GDI+ Startup information
          Private Type GdiplusStartupInput
              GdiplusVersion As Long
              DebugEventCallback As Long
              SuppressBackgroundThread As Long
              SuppressExternalCodecs As Long
          End Type
          LoadPictureGDI "E:\test.bmp"
          Public Function LoadPictureGDI(ByVal sFilename As String) As IPicture
              Dim uGdiInput As GdiplusStartupInput
              Dim hGdiPlus As Long
              Dim lResult As Long
              Dim hGdiImage As Long
              Dim hBitmap As Long
              Dim xPos As Integer
              Dim yPos As Integer
              Dim lRGB As Long
              Dim lHeight, lWidth As Long
              Dim R, G, B As Long
              xPos = 1
              yPos = 0
              'Initialize GDI+
              uGdiInput.GdiplusVersion = 1
              lResult = GdiplusStartup(hGdiPlus, uGdiInput)
          If lResult = 0 Then
              'Load image from file
              lResult = GdipCreateBitmapFromFile(StrPtr(sFilename), hGdiImage)
              If lResult = 0 Then
                  lResult = GdipBitmapGetPixel(hGdiImage, xPos, yPos, lRGB)
                  lResult = GdipGetImageHeight(hGdiImage, lHeight)
                  lResult = GdipGetImageWidth(hGdiImage, lWidth)
                  B = lRGB And 255
                  G = (lRGB \ 256) And 255
                  R = (lRGB \ 65536) And 255
                  Debug.Print "RGB as Long: " & lRGB
                  Debug.Print "Image size [px]: " & lHeight & "x" & lWidth
                  Debug.Print "RGB(" & R; "," & G & "," & B & ") @ (" & xPos & "," & yPos & ")"
                  'Dispose image from memory
                  GdipDisposeImage hGdiImage
              'Shutdown
              GdiplusShutdown hGdiPlus
          End Function
            Daniel Andersson
            AH! I did not give up and found a alternative way of and use of gdi32 instead. I have tried to find out the difference between gdiplus calls and gdi32. Seems like it is just to dig into the MSDN site and get some understanding of the C++ syntaxes for the functions.
            Found some of the code and modified it to do what you are looking for.
            This code do give the correct RGB values compared to the attempt above with GDI+.
            Const IMAGE_BITMAP = &O0
            Const LR_LOADFROMFILE = 16
            Const LR_CREATEDIBSECTION = 8192
            Private Type BITMAP
               bmType As Long
               bmWidth As Long
               bmHeight As Long
               bmWidthBytes As Long
               bmPlanes As Integer
               bmBitsPixel As Integer
               bmBits As Long
            End Type
            Private Declare Function LoadImage Lib "user32" Alias "LoadImageA" (ByVal hInst As Long, ByVal lpsz As String, ByVal un1 As Long, ByVal n1 As Long, ByVal n2 As Long, ByVal un2 As Long) As Long
            Private Declare Function CreateCompatibleDC Lib "gdi32" (ByVal hdc As Long) As Long
            Private Declare Function SelectObject Lib "gdi32" (ByVal hdc As Long, ByVal hObject As Long) As Long
            Private Declare Function GetObject Lib "gdi32" Alias "GetObjectA" (ByVal hObject As Long, ByVal nCount As Long, lpObject As Any) As Long
            Private Declare Function DeleteDC Lib "gdi32" (ByVal hdc As Long) As Long
            Private Declare Function DeleteObject Lib "gdi32" (ByVal hObject As Long) As Long
            Private Declare Function GetPixel Lib "gdi32" (ByVal hdc As Long, ByVal x As Long, ByVal y As Long) As Long
            Dim averageG As Integer
            Dim averageB As Integer
            GetAverageRGB "E:\test.bmp", averageR, averageG, averageB
            Debug.Print averageG
            Debug.Print averageB
            Public Function GetAverageRGB(ByVal FileName As String, R As Integer, G As Integer, B As Integer)
            Dim hBitmap As Long
            Dim lBMDC As Long
            Dim sBitmapInfo As BITMAP
            Dim lRGB As Long
            Dim xPos As Long
            Dim yPos As Long
            Dim intR As Integer
            Dim intG As Integer
            Dim intB As Integer
            Dim totalR As Long
            Dim totalG As Long
            Dim totalB As Long
            Dim totalPixels As Long
            'Load the bitmap
            hBitmap = LoadImage(0, FileName, IMAGE_BITMAP, 0, 0, LR_LOADFROMFILE Or LR_CREATEDIBSECTION)
            'make sure the call succeeded
            If (hBitmap = 0) Then
               MsgBox "Error, Unable To Load Bitmap", vbOKOnly, "Bitmap Load Error"
               Exit Function
            'Create new Device Context
            lBMDC = CreateCompatibleDC(0)
            If (lBMDC = 0) Then
               MsgBox "Error, Unable To Create Device Context", vbOKOnly, "Device Context Error"
               Exit Function
            'attach the bitmap to the device context just created
            SelectObject lBMDC, hBitmap
            'get the information about this image
            GetObject hBitmap, Len(sBitmapInfo), sBitmapInfo
            totalPixels = sBitmapInfo.bmWidth * sBitmapInfo.bmHeight
            For yPos = 0 To sBitmapInfo.bmHeight - 1
                For xPos = o To sBitmapInfo.bmWidth - 1
                    lRGB = GetPixel(lBMDC, xPos, yPos)
                    getRGB lRGB, intR, intG, intB
                    totalR = totalR + intR
                    totalG = totalG + intG
                    totalB = totalB + intB
                Next xPos
            Next yPos
            R = totalR / totalPixels
            G = totalG / totalPixels
            B = totalB / totalPixels
            DeleteDC lBMDC
            DeleteObject hBitmap
            End Function
            Private Function getRGB(ByVal lngRGB As Long, R As Integer, G As Integer, B As Integer)
                    R = lngRGB And 255
                    G = (lngRGB \ 256) And 255
                    B = (lngRGB \ 65536) And 255
            End Function
                Kelson Lachance
                Wow the effort here is outstanding.  I have been in meeting so I apologize for the delay.  I tried the first this morning to see but had a problem with the gdiplus initializing.
                I am still using VBA on a 64 bit machine, so do I have to find and add the user32 and gdi32 dll as resource library for this code to work?
                The sad truth is; is that I have been working on solving the original problem for 6 years; using this bitmap method may be the answer; so I am eager.
                kelson
                    Daniel Andersson
                    I created the macro in 64-bit, Windows 7. You do not have to add any references in the macro (tried macro in SolidWorks and Excel and it works fine in both). Just copy and paste it.
                    I would recommend that you run the macro that uses gdi32 methods instead. Since the one with gdiplus gives wrong RGB values, still have not figured out why... perhaps it is due to bits and bytes... :S
                        Kelson Lachance
                        Ok-  I appreciate you help with my obsession.  Strange don't understand but it does work when I loaded into Excel.
                        I had to change some variable to Long; I think it was because my bitmap was large.
                        The count seems to be off on the RGB values returned.
                        My understanding is that this function will return a 1 for one of the R, G, B variables during each loop.  I guess I don't understand the lngRGB as long;
                        Private Function getRGB(ByRef lngRGB As Long, R As Integer, G As Integer, B As Integer)
                                R = lngRGB And 255
                        End Function
                        Can you help me with my understanding.  The internet suggest the RGD is a hexadecimal format.  You have been more than helpful so if you want to just point me in the right direction; I will understand.
                            Daniel Andersson
                            Found out that these should be long... otherwise the variables will overflow.
                            Dim totalR As Long
                            Dim totalG As Long
                            Dim totalB As Long
                            The function getRGB returns the R, G and B values as integers from a long (RGB) value.
                            R = lngRGB And 255 'The AND is a bit operation since the values are numeric, I do not have the right level of knowledge to explain this. You find better answers if you google.
                                    lRGB = GetPixel(lBMDC, xPos, yPos) 'Gets the long value for of RGB for specified pixel.
                                    getRGB lRGB, intR, intG, intB 'Funtion getRGB, the lRGB is passed to the function and it returns values to intR, intG, intB.
                                    totalR = totalR + intR 'Summarize the total R values for the complete bitmap.
                                    totalG = totalG + intG '.....
                                    totalB = totalB + intB '....
                                Next xPos
                            Next yPos
                            RGB can be in decimal form (R,G,B) hexadecimal and hexadecimal can be converted to long values. In this case I chose to split up the lRGB into integers for R, G and B. Reason for integer is that a RGB value can not be a decimal. E.g. you can not set RGB(242.2, 1.5, 175.4)
                            As an example, the attached 2x2 bitmap image have three black RGB(0,0,0) pixels and one red RGB(255,0,0) pixel.
                            This will return a average RGB value of RGB(64,0,0) for the complete bitmap. Since R = 255/4 = 63,75, G = 0 / 4, B = 0 / 4.
                            The values that is printed in the immediate window is just these average RGB values.
                            What do you see as off in the RGB values that is returned? Reversed order of RGB (coming as BGR)? Or is it that the function seems to round off the values for each pixel?
                            Would it be possible for you to attach a bitmap that I could test with?
                                Kelson Lachance
                                You are exactly right.  Your explanation were clear for a notice like me.  This is just fantastic.  I got this to work and completely understand.
                                Works perfectly within Excel.  Once again thanks for your help.  This solve a problem I have honestly been working on for a long time.
                                  Kelson Lachance
                                  I am having problem with is running in Solidworks; which uses the VBA 7 versus 6 in Excel
                                  For some reason it is forcing me to use the prtsafe  when declaring functions but does not seem to work; which is one of difference in the versions.
                                  I don't think it is loading or initializing the Functions.
                                  Any ideas?  Frustrated as I am so close.
                                      Simon Turner
                                      You do need to add PtrSafe to all the Declare statements. And any variable that refers to a memory pointer needs to be changed from Long to LongPtr
                                      Google "Declare functionname VBA7" and you should find the syntax you need. For example:
                                      Private Declare PtrSafe Function GdipCreateHBITMAPFromBitmap Lib "GDIPlus" (ByVal bitmap As LongPtr, hbmReturn As LongPtr, ByVal background As Long) As LongPtr
                                          Kelson Lachance
                                          Yes thank you.  I did start to change the code last night with respect to what you are suggesting.  It is shown below, I have tried many combinations changing what I believe to be memory pointer to the LongPtr as well.  I just think I am missing something obvious to a trained eye.
                                          Private Type BITMAP
                                             bmType As Long
                                             bmWidth As Long
                                             bmHeight As Long
                                             bmPlanes As Integer
                                             bmBits As Long
                                          End Type
                                          '__________
                                          Private Declare PtrSafe Function LoadImage Lib "user32" Alias "LoadImageA" (ByVal hInst As Long, ByVal lpsz As String, ByVal un1 As Long, ByVal n1 As Long, ByVal n2 As Long, ByVal un2 As Long) As LongPtr
                                          Private Declare PtrSafe Function CreateCompatibleDC Lib "gdi32" (ByVal hdc As LongPtr) As Long
                                          Private Declare PtrSafe Function SelectObject Lib "gdi32" (ByVal hdc As LongPtr, ByVal hObject As LongPtr) As Long
                                          Private Declare PtrSafe Function GetObject Lib "gdi32" Alias "GetObjectA" (ByVal hObject As LongPtr, ByVal nCount As LongPtr, lpObject As Any) As Long
                                          Private Declare PtrSafe Function DeleteDC Lib "gdi32" (ByVal hdc As LongPtr) As Long
                                          Private Declare PtrSafe Function DeleteObject Lib "gdi32" (ByVal hObject As LongPtr) As Long
                                          Private Declare PtrSafe Function GetPixel Lib "gdi32" (ByVal hdc As LongPtr, ByVal x As Long, ByVal y As Long) As Long
                                          GetAverageRGB "C:\test.bmp", averageR, averageG, averageB
                                          Public Function GetAverageRGB(ByRef FileName As String, R As Integer, G As Integer, B As Integer)
                                          Dim hBitmap As LongPtr
                                          Dim lBMDC As LongPtr
                                          Dim lRGB As Long
                                          Dim xPos As Long
                                          Dim yPos As Long
                                          Dim intR As Integer
                                          Dim intG As Integer
                                          Dim intB As Integer
                                          Dim totalR As Long
                                          Dim totalG As Long
                                          Dim totalB As Long
                                          Dim totalred As Long
                                          Dim totalblack As Long
                                          Dim maxboxlength As Long
                                          Dim largestmaxboxlength As Long
                                          Dim previouspixelred As Boolean
                                          'Load the bitmap
                                             Exit Function
                                          If (lBMDC = 0) Then
                                             Exit Function
                                          Debug.Print sBitmapInfo.bmWidth & " " & sBitmapInfo.bmHeight
                                          Debug.Print totalPixels
                                          previouspixred = False
                                          largestmaxboxlength = 0
                                                  'Debug.Print xPos & " " & yPos
                                                  If intR > 175 And intG < 50 And intB < 50 And previouspixelred = True Then
                                                    maxboxlength = maxboxlength + 1
                                                  If intR > 175 And intG < 50 And intB < 50 Then
                                                    totalred = totalred + 1
                                                  If intR < 40 And intG < 40 And intB < 40 Then
                                                    totalblack = totalblack + 1
                                                    previouspixelred = False
                                              Next xPos
                                                If maxboxlength > largestmaxboxlength Then
                                                  largestmaxboxlength = maxboxlength
                                              maxboxlength = 0
                                          Next yPos
                                          'R = totalR / 1
                                          'G = totalG / 1
                                          'B = totalB / 1
                                          Debug.Print "TotalPixels" & " " & totalPixels
                                          Debug.Print "Red Pixels" & "  " & totalred
                                          'Debug.Print "Total Area" & "  " & totalred
                                          Debug.Print "Total Black" & " " & totalblack
                                          Debug.Print "Total Picture Pixels " & " " & totalblack + totalred
                                          Debug.Print "Number of pixel in Red row" & "  " & largestmaxboxlength
                                          DeleteDC lBMDC
                                          End Function
                                                  R = lngRGB And 255
                                          End Function
                                              Simon Turner
                                              This is a good site to refer to: http://www.cadsharp.com/docs/Win32API_PtrSafe.txt
                                              Using that, you can see that the hInst argument of LoadImage should be LongPtr.
                                              I'll paste in all the declares you need below:
                                              Declare PtrSafe Function LoadImage Lib "user32" Alias "LoadImageA" (ByVal hInst As LongPtr, ByVal lpsz As String, ByVal un1 As Long, ByVal n1 As Long, ByVal n2 As Long, ByVal un2 As Long) As LongPtr
                                              Declare PtrSafe Function CreateCompatibleDC Lib "gdi32" Alias "CreateCompatibleDC" (ByVal hdc As LongPtr) As LongPtr
                                              Declare PtrSafe Function SelectObject Lib "gdi32" Alias "SelectObject" (ByVal hdc As LongPtr, ByVal hObject As LongPtr) As LongPtr
                                              Declare PtrSafe Function GetObject Lib "gdi32" Alias "GetObjectA" (ByVal hObject As LongPtr, ByVal nCount As Long, lpObject As Any) As Long
                                              Declare PtrSafe Function DeleteDC Lib "gdi32" Alias "DeleteDC" (ByVal hdc As LongPtr) As Long
                                              Declare PtrSafe Function DeleteObject Lib "gdi32" Alias "DeleteObject" (ByVal hObject As LongPtr) As Long
                                              Declare PtrSafe Function GetPixel Lib "gdi32" Alias "GetPixel" (ByVal hdc As LongPtr, ByVal x As Long, ByVal y As Long) As Long
                                              Simon
