Analyse Electric Motor that we must use on a movement system
Question asked by Designer Designer on May 3, 2007
Latest reply on Sep 16, 2007 by Ian Hogg
Dear Cosmos Users.....
I have a movement system contains of some part, electrical motor & hydraulic, pneumatic element. I have CW Designer & CM 2007.
I want to :
1. Analyse which type of electrical motor that can rotate my rotary system. Let`s say I have motor with 100, 200, and 300 Watt.
In case I have installed my 100 watt motor. Then when I turn on the motor, the system can`t be rotate by the motor ( over load ). So I want to analyse using cosmos before I install motor on a real life. Is that possible to analyse that using CW or CM.....???
2. Another case is I have hydraulic system. How much pressure should be put on the system so the system can moved by the hydraulic cylinder smoothly. How to analyse this on CW or CM ???
I hope any body can share experience on this case.
Regards,
-DD
