Hi Chad, what you can do is use the Print Task within EPDM. You can run this task on demand, or while undergoing a workflow transition. As for printing all drawings related to a assembly, you could put all the related files (assemblies, parts, drawings) through a workflow transition (eg Release Files) and then have the task run only for files with the extension slddrw.
Hope this helps
Prasad Bhonsule
