BSBrendan Shute08/01/2015
I am having some issues with my line thickness when I print or save to PDF versus print to PDF. I have attached a comparison between the two, with test.pdf being the drawing I get if I print to sheet or save to PDF and test2.pdf the drawing I get from printing to PDF using CutePDF. test2 is the correct version. Most notable are the lack of difference to the heavy boarder lines and stamp boarder thickness. It appears though Solidworks is not plotting drawing thicknesses when printing or saving to PDF although I am unsure why. All settings are identical between methods, and I have used the printer in AutoCAD to check its ability to plot correct line weights, where there was no problem.
