Although there were not any problems in SW2015 SP1.0, in SP1,1 one cannot open a ECAD file or do anything related to Circuitworks. For example when one tries to open Circuitwork's options or library SW returns with a SQL error. Does anybody else come across such problem?
Hi Safa
This is a known issue reported under SPR 838169
A possible workaround is Close SolidWorks and copy and replace createdb.sql and createdblite.sql from Client installed 2015SP0 to the client installed 2015SP01 version. After replacing CircuitWorks should work correctly. These two files are located at following path : <SolidWorks installation location>\SOLIDWORKS Corp\SOLIDWORKS\CircuitWorksFull.
(backup the files in this directory first)
for convenience i'll attach the files to this thread.
Cheers
Alan
