After an upgrade from EPDM 2013 SP3 to EPDM 2015 SP 1.1, one of my add-in is failing at the point where it moves a file using IEdmFile::Move. The error message is:
"An attempt was made to move a file to another location"
Well, yes, that is what the Move method is supposed to do. Some testing shows that the problem exists if I try to move the file manually as well:
Permissions problem right? Well, I cannot seem to find the permission that I missed. In both the source and destination folders I have add/delete/move/rename permissions. I also have add/delete/move permissions for the state the file is in.
Nothing has been changed by me via the EPDM Admin tool. This all worked correctly before the upgrade to 2015.
Has anyone else encountered this problem?
I've not tested it yet, but I bet "move" is effected by "ignore permissions from previous states". Temporarily turn that option on in the workflow state to see if you can move the file.
