I made a rectangle shell. I would like to add an apron/flange extending from opposing ends and still keep the part one-piece.
What version of SolidWorks are you using?
For a vacuum formed part you will want a bit of a draft angle on the sides.
Have you already started the part - can you attach what you have completed so far?
I might do this a bit differently than most - I would do a couple of Extrude features and perhaps split some faces and Shell.
If I knew what version of SolidWorks you are using - I could take the time to create an example. (see attached)
There are any number of ways to accomplish this. One would be to draw a sketch on the top edge of the shell that is the size of the flange you want and then extrude it, being sure to check the merge box.
