Hi, I have a question regarding Flow Simulation in SW. I am new to it so I'm trying to get an understanding of what is possible.
Suppose I have a water turbine design and I want to find out how good my design is - Is it possible to simulate the rotation speed of the turbine given various velocities of water through the turbine? Is it possible to actually simulate rotation at all? In the tutorials I have found so far, the user would *set it up* to rotate and give it a direction, as opposed to having it rotate *as a result of* the flow. Is this even possible with any of the CFD analysis software currently available?
Thanks!
Flow Sim does not simulate fluid-structure interaction, so the short answer is "no". I'm not 100% positive, but I think there may be software out there with this capability, ANSYS most likely. Flow Simulation will allow you to take your model and run it as a pump, that may give you some insight as to the effectiveness of your design.
