weldment section dimension does not match actual size?
Question asked by Kevin Zhu on Jan 6, 2015
Latest reply on Jan 6, 2015 by Kevin Zhu
Hi, I am seeking help with a weldment problem here:
I have set up weldment of standard steel section using weldment template controlled by a design table. it works fine at work. but when I bring the work home, the weldment sketch started to have errors. The sketch dioumension does not match the actual size. I am using 2014 sp3 by the way. I Have attached a picture showing this error. You can see from the sketch, the leg size of the angle is 50. but from measurement tool, the actual member has a leg size of 100. Rebuild doesn't not solve the problem. I have check my design table and everything is correct. has anyone encountered this?
