In the assembly I'm working on, I have designed a cap for a part. The cap's sketch lines are referenced to the points of the corners of the the main body the cap will be placed on. I have applied some fillets at the main body and now all my references show there is an error. Is there a way/ an option for SW to show the corner points? I thought there would be one in the "snaps" tab but there isn't.
Thanks in advance for any help!
Antonis,
It is my custom to not make references to edges or vertices (if I can help it!) exactly because fillets that get added later can eliminate the referenced edges. Split lines will also mess up references to edges or vertices.
Whenever possible, the best practice is to show the sketches that were used to make the edges or vertices in the first place, and then make your references to lines and corners in those sketches. This is a much more stable workflow with drastically fewer surprises - if your design allows for it, of course.
