DBDonald Belliveau05/01/2015
Having problem with saving Document Properties to Drawing/Sheet Format. Under Options / Document Properties / Dimensions I'm keep changing dimension standards from ISO to ANSI and the Unit Precision to .123. I change Angle through Radius and click OK then "Save Sheet Format". Then opening Drawing/Sheet Format it goes back to ISO Unit Precision to .12. The Overall drafting standard states ANSI. How do you save for default settings?
