2 Replies Latest reply on Jan 12, 2015 2:05 AM by Josemi Antelo
    ICustomPropertyManager::Get5 Don't works
    Josemi Antelo
      Hello
         I'm trying to use ICustomPropertyManager::Get5 but don't Works.
         To you it Works?
         Could you pass me an example?
      I use VS2013 C++
      Many thanks in advance
        • Re: ICustomPropertyManager::Get5 Don't works
          Keith Rice
          Josemi,
          Not many people here use C++ with the API, so it would be best if you clarified which of these is your problem:
          1. I do not know how to use ICustomPropertyManager::Get5 at all, in any language.
          2. I am able to use ICustomPropertyManager::Get5 in VBA (or some other language), but I am not able to get it to work in C++.
          I don't have time right now to set up a stand-alone to verify #2, but as for #1, here is how you would use it in a C# macro:
          using SolidWorks.Interop.sldworks;
          using SolidWorks.Interop.swconst;
          using System.Runtime.InteropServices;
          using System.Diagnostics;
          namespace Macro1.csproj
              public partial class SolidWorksMacro
                  public void Main()
                      ModelDoc2 swModel = (ModelDoc2)swApp.ActiveDoc;
                      CustomPropertyManager swCustPropMgr = swModel.Extension.get_CustomPropertyManager(null);
                      string valOut;
                      string resolvedValOut;
                      bool wasResolved;
                      swCustPropMgr.Get5("Revision", false, out valOut, out resolvedValOut, out wasResolved);
                      Debug.Print("Value: " + valOut + System.Environment.NewLine +
                                        "Resolved value: " + resolvedValOut + System.Environment.NewLine +
                                        "Was the value evaluated? " + wasResolved.ToString());
                  public SldWorks swApp;
          Note that this method uses "out" arguments, meaning that information is given back to you rather than you passing information in. Basically, it allows a function to return multiple values without having to use a string array.
          Explanation of arguments:
          The "value" and the "resolved value" correspond to these two highlighted boxes in the custom properties dialog in the UI:
          Notice that for Material, the value and the evaluated value are different.
          As for the "wasResolved" out argument, this indicates whether the value successfully evaluated.
          Keith
          SolidWorks API Tutorials
              Josemi Antelo
              Hi Keith
              First of all, thank you very much for answering my question.
              The question, really, is that in C ++ the Get5 does not work and wanted to know if there was someone who worked him. The output parameters are (BSRT *) and as much as I've tried, the function aborts. I sincerely believe that the problem is Solidworks. In the end I had to use the obsolete function Get.
              Yours sincerely
              Josemi
