6 Replies Latest reply on Feb 23, 2015 5:50 PM by Jon Proffitt
    Get Dimension Type
    Jon Proffitt
      New to SW API, long time user on the NX API boards , new company has SW which I haven't used in a few years.
      Im trying to use GetSelectedObject6 to cycle thru dimensions and split them into linear dimensions, radius, diameter, angle etc.
      Sofar I have. My Issue is that swDisplayDimension.Type2 is giving a value of 2 for linear dimensions and also diameters....
      I am basing this code off a similar API instructions to get dimension types.  Thanks!
      Dim swDisplayDimension As SldWorks.DisplayDimension
      Dim swDimension As SldWorks.Dimension
      Dim swDimensionTolerance As SldWorks.DimensionTolerance
      Dim status As Boolean
      Dim fontHeight As Double
      Dim fontScale As Double
      Dim swView As SldWorks.View
      Dim swAnn As SldWorks.Annotation
      Set swModel = swApp.ActiveDoc
      Dim DimVal As Double
      Dim index As Long
      Dim Tol As String
      Dim DimType As Integer
      Dim DimTypeSel As String
      Dim Post As String
      Dim CalcNum As Double
      CalcNum = 0.0254
      For index = 1 To swSelMgr.GetSelectedObjectCount
          'Get the selection
          Set swDisplayDimension = swSelMgr.GetSelectedObject6(index, 0)
          'Set swAnn = swSelMgr.GetSelectedObject6(index, 0)
          Set swDimension = swDisplayDimension.GetDimension
          DimVal = swDimension.Value
          Set swDimensionTolerance = swDimension.Tolerance
          Set swAnn = swDisplayDimension.GetAnnotation
          'Debug.Print swAnn.GetName
          'Debug.Print swAnn.GetType
          Set swDisplayDimension = swAnn.GetSpecificAnnotation
          DimType = swDisplayDimension.Type2
          Debug.Print DimType
          ' CASE SELECTION
          Select Case (DimType)
          Case 1
          DimTypeSel = ""
          'Debug.Print DimTypeSel
          Case 2
          DimTypeSel = "Ø" ' Dia
          Case 3
          DimTypeSel = "" ' Angle
          CalcNum = 0.01745329
          Case 4
          DimTypeSel = ""
          Case 5
          DimTypeSel = "R" ' R
          Case Else
          DimTypeSel = ""
          End Select
          ' END SELECTION
      blah blah some stuff to export to Excel
        • Re: Get Dimension Type
          Keith Rice
          Jon,
          Next time, please include all information necessary to repeat the problem, like what document type you're using and what your dimensions look like. If you could upload a model, that would be best. Moreover, as a courtesy, please 1) remove irrelevant code from your snippet before you post it, 2) test the snippet to make sure it works (this snippet doesn't since you left out End Sub).
          Nevertheless, if I had to guess, you're selecting a double distance dimension, which does record a diametric value but does so using a linear dimension. If that's the case I can show you how to test for whether a dimension is double distance, and then you can mark it as diametric.
          Keith
          SolidWorks API Video Tutorials
              Jon Proffitt
              Keith,
              You are correct in the issue as I am trying to select a diameter and it also records as a linear dimension. I am trying to differentiate between the linear and diameter records. What is the proper method for testing between the two types as you mentioned? This is the code now and the value returned in debug.print is the same for both diameters and linear dimensions unfortunately.
              Option Explicit
              Dim index As Integer
              Dim DimType As Double
                  'Get the selection
                   'If selection is not a dimension, then exit
                  If swSelMgr.GetSelectedObjectType3(1, -1) <> swSelDIMENSIONS Then Exit Sub
                ' Selection is a dimension, so get the dimension tolerance object
                  Debug.Print "Dimension Type is: " & DimType
              Next index
                  Keith Rice
                  Jon,
                  Artem wrote a function here for how to determine if a linear dimension is diametric. The criteria for whether a linear dimension is diametric are:
                  1. The dimension must have a DOUBLEDISTANCE constraint type associated with it.
                  2. The dimension must be attached to two sketch segments.
                       a. One of these sketch segments must be construction.
                       b. The other sketch segment must not be construction.
                  Keith
                  SolidWorks API Tutorials
                  1 person found this helpful
                JOHN GEORGE
                Jon,
                There is another discussion on the same subject
                I am not a code expert, still hope this will help you to solve the issue
                See this
                    Jon Proffitt
                    John,
                    I was using that post as a guideline in which it was very helpful. My only issue is, when I use the GetSelectedObject6 function ( since I am only trying to run this macro for a selected group of dimensions) and use the swDisplayDimension.Type2 , it returns the same value 2 for linear and diameter. I'm unsure how to differentiate these two type, however that approach works for arcs (value of 4) , radii (value of 5) , and angles (Value of 3) perfectly. Diameter should be value of 6 ... but being recorded as 2
                    I feel like I am misunderstanding how the .Type2 interacts with objects in a GetSelecedObject6.
                    Jon Proffitt
                    Hey, just resolved the issue I was having awhile ago.
                    I used
                    Dim strDimensionTextCalloutAboveDefinition As String = swDisplayDimension.GetText(swDimensionTextParts_e.swDimensionTextCalloutAboveDefinition)
                    Dim strDimensionTextPrefixDefinition As String = swDisplayDimension.GetText(swDimensionTextParts_e.swDimensionTextPrefixDefinition)
                    Then Solidworks uses a <MOD-DIAM> as a return on that
                    I then used Replace(strDimensionTextPrefixDefinition, "<MOD-DIAM>, "ø ") and now it knows its a diameter....sorry for long fix! Hope this helps someone.
